Well, if you look at post #80
, the sketch isn't very proportional. If the enclosure is 13.5" wide, and the 12W3 is 12.5" wide OD, there will only be .5" of "shoulder" to rest on the false baffle. I suppose it's physically possible, but I would rather have a bit more overlap for sealing/insulating purposes. I guess the small area where the overlap is that narrow won't make a massive difference. I'll need to sketch it up to scale and take a look.
Why do you suggest using the 12W3V3? We've been discussing 10" drivers pretty much from the start.
 How would enclosure size requirements differ amongst, just for example, the 8W7, 10W6V2 and the 12W3V3? If I'm told that a conventional sub is the most acceptable, enclosure size is sure to be an issue.
