Under $1k for a multi-channel?
AndrewLyles
Thanks
Umm thanks?... what is a switching amplifier? Talk about a noob thread here hmm? I'm learning as I go though, promise!
Z
zumbo
I am learning too. Thats why we are here. Everyone can help in some way, that way we all get better at our hobby. And, the products get better too.
I found this in an article about audio amp classes.
About.com-Anthony Armstrong. Complete article:http://stereos.about.com/od/homestereotechnologies/a/amp_op_classes.htm
Class D
These amplifiers are erroneously called "digital" amplifiers by the press and many audio "experts." Here's the skinny on Class D:
While some Class D amps do run in true digital mode, using coherent binary data, most do not.
They are better termed "switching" amplifiers, because here the output devices are rapidly switched on and off at least twice for each cycle.
Depending on their switching frequency, they may be "switched on" or "off" millions of times a second.
Class D operation is theoretically 100% efficient, but in practice, they are closer to 80-90% efficiency.
This efficiency gain is at the cost of high-fidelity.
Think of Class D amps as being similar to a switchable power supply, but with audio signals controlling, or modulating, the switching action. To do this, you use a technology called Pulse Width Modulation (or PWM, a technology found in many CD players).
According to experts, audio signals can be used to modulate a PWM system to create a high power audio amplifier at fairly low voltages using very small components. Class D audio uses a fixed, high frequency signal having pulses that vary in width based on input signal amplitude. So, for example, a deep bass note creates a large pulse in the carrier signal. This can be translated into a musical signal by the on/off nature of the output devices.
WmAx
WmAx
zumbo said:
Class D
Note: For purposes of copyright, please credit the specific source of information when it is copied verbatim from another source.
BTW, modern well-designed switching amplifiers need not give up anything in terms of audio quality. Early switching amplifiers did not operate at a sufficiently high switching frequency. Switching amplifiers also entail classes such as 'T' and 'H', in addition to 'D'. I might be missing some others, but those are the ones I remember at the moment.
-Chris
WmAx
WmAx
zumbo said:
Is that a yes he can run them, or no?
He can determine this by using the information I provided. However, this relates to the maximum continous power output potential, not safe operation.
-Chris
Z
zumbo
WmAx said:
Note: For purposes of copyright, please credit the specific source of information when it is copied verbatim from another source.-Chris
I made the notation. Thanks.;) I usually mention it, or link it. It was such a long article, I just did it this way.
AndrewLyles
Okay, I gotcha. This sounds very similiar to what is used to give Automotive amplifiers their punch. Switching back and forth as a means of not overloading the system.
