UHD calibration help
pewternhrata
Ratings
173 2
#1
LG UH6150, Xbox one s.
I used the built in calibration on the Xbox to calibrate what it offered, basics such as brightness backlight contrast, I used the cinema mode on the lg. It made a decent difference and have no complaints (looking to possibly using something else, but for now I'm very pleased with it)
I picked up my first 4k disk today, fifth element, and this is where my question starts. I started playing the movie and it looked wayyy too bright. I figured my 2yr old might have been playing with the remote so I checked the mode the tv was on. My cinema user is not an option, only a few preset uhd modes that thankfully I can edit. Question is, how do I get the uhd mode to edit? If I go back through with the Xbox calibration my tv only gives me the 'standard' display modes, the uhd modes are not available (only available when playing the 4k disk)
Do I need a 4k disk that contains calibration?
everettT
everettT
Ratings
1,006 9 11
#2
Have you considered a calibration disc? The under $200 self calibration units work pretty good. IIRC LG offers ISF access via the standard menu.
panteragstk
panteragstk
Ratings
1,137 6
#3
Try these settings. Rtings is a pretty good place to start.
pewternhrata
Ratings
173 2
#4
That was a big help. I was close on most from what I had done. The big change was the gamma and color temp. I had gamma at bt1886 I believe, and at 2.2 there was a slight improvement. I had temp at cool, but going back to warm2 smoothed out to a more natural image (I had initially set it to warm2 but it looked too red/amber, assuming with the other settings that helped)
With hdr I will go through and use these settings as a baseline to start and hope that gets me a little better than where it is now. One thing I hate is the soap opera effect, on hdr if it is turned off it gets grainy, so hopefully I can get that under control.
I know without pro calibration ill never be perfect, but this is also in a family room where the ambient light changes drastically during the day, but for any critical watching it is almost always dark. Again big thanks.
panteragstk
panteragstk
Ratings
1,137 6
#5
No problem. Their settings did great for my Sony. HDR stuff looks great.
