Old thread, but I have this receiver working well so thought I would add. TX-NR636, with a Audio-technica AT-LP120XUSB TT, powering soundstage 3D series 150W towers. I upgraded the cartridge to the AT-VM95ML/H (red), but played for a few months with the AT-VM95E (green) that it came with. This TT has a built in pre-amp that you can bypass with a switch. Forgot to bypass it first play, and wow that sounded bad. But when running direct to the phono input, WITH A GOOD GROUND, the system sounded very reasonable. With the standard cartridge the highs were a bit bright and even slightly distorted, may have been a damaged needle. But after upgrading to the nude square shank needle, I was very impressed. The full range is coming through clear as good or better than listening through spotify. Nothing here is very high end, but it sounds plenty good for my ears.
