R redd454 Audioholic Jul 16, 2018 #21 highfigh said: ART Audio is a company that sells accessories. If you're using four receivers, just connect the Rec Out to Aux on each successive AVR until you reach the last one. Click to expand... thanks, this i'll do, also, is there any way i can hook my second rx-v2095 in line, and use the zone two aux remote? as the original remote's interfere with each other, what you select on one, affects both rx-v2095, or since i would have the other rx-v2095 set to aux,instead of remote position it would not make a diff? in hooking up rec. out to aux. in, do i need to set front selector on aux.
