<font color='#000000'>I went through the same exercise recently. In addition to Music Hall and Rega, you might consider Pro-ject and Thorens. All are well regarded for their prices. Reviews are easy to find.
Once you've decided, spend decent money on a cartridge. Then set up a good fluid-based cleaning system. If your LPs have sat unplayed for a long time they will definitely be in need of restoration. You can do well with manual methods, you don't need a machine (but you WILL want one!)
There's lots of advice and info onthe web. One place to start is The Vinyl Tourist, and cruise the links from there</font>
