turntable to speakers via miniplug
steptb6
i am looking to purchase a Audio Technica AT-PL50 Belt Drive Turntable and would like to hook it up to my Klipsch ProMedia 2.1 Multimedia Speaker System. The turntable has an internal preamp and a stereo RCA-to-1/8-inch miniplug stereo adapter cable. what other equipment would i need to connect the two systems? Thanks in advance.
Adam
Adam
Hey, welcome to the forum.
I think that you're all set. Those two should work together without anything else being needed.
MDS
If the turntable has a built-in preamp then you have everything you need. Just connect the mini plug to the aux in or other line-level input of the speakers.
steptb6
thanks for your timely replies- that is exactly what i was hoping to hear
