45 to 50 miles isn't as distant as I thought you were. Do you notice that reception quality is better on an overcast day vs. a clear day? Do you also receive HDTV over the air? I find I can easily get HDTV signals from Baltimore (over 50 miles away) that, when decoded, are much clearer than analog FM radio from that distance.
That alone explains a lot. My earlier post about signal strength and hi-gain antennae was nothing more than wondering out loud. Most of what I knew about radio back then had nothing to do with civilian radio, and I was never much interested in short wave ham radio. I did have to learn Morse code (the Soviet Navy may have been the only Morse code user in the world), and when I left the Navy, I was most certainly done with that.
Maybe that rules out your antenna. I wonder if the interference is picked up by the cable or the Quad receiver itself. Shielding built into those devices may not have anticipated the level of noise from those LED lights.
You could be right about that. However, in the eastern cities, where I live, the air waves are loaded with high signal strength TV and FM radio. Antenna gain is not the issue I face, it's selectivity. But that is more easily dealt with than noisy light bulbs.
Thanks for those two links.
