Trouble with Yamaha Remote RAV228
sruszak
The small display screen on my Yamaha RAV228 remote isn't working. It lights up but no text appears to help guide any control efforts. Do I need a new remote or can this problem be somehow fixed? I already replaced the batteries.
It sounds like new remote time to me.
WaynePflughaupt
WaynePflughaupt
That's a pretty old remote. You can get a replacement for probably 1/3 the price it would cost to have it fixed, even if you could find a shop that does that, and if there are parts available for it.
Edit:
You might even be able to find one on ebay for less.
Regards,
Wayne A. Pflughaupt
The screen going out, is not a bi issue, as you can see it on your TV screen and the receiver display.
The original is not available but there are other remotes
I have replaced two Marantz remotes now with Rediremotes from remotes.com. This is the one you need.
They do not have a screen. However they have a really solid feel and are well made. They actually perform better than the originals, and are excellent value.
