"Transparent and Clinical" sounding floor speakers
  • Thread starter TheloniousEllington
  • Start date
BoredSysAdmin
BoredSysAdmin
Thanks for the input. The SS8 look and seem like they'd be perfect. If the Song Veracity and the Song Tower sound similar to the Soundscape in voicing, what affect do the tiers/series have on differences in sound? I see different combinations on speaker types and cabinet shapes. I'm still understanding these ideas. It's interesting to know that a voicing can be similar because of crossover precision, but why different models with the same crossovers can have different tonal characteristics and how...
Jim Salk makes great speakers, but bang for the buck it'd be hard-pressed to beat on above mentioned BMR Tower speakers. As for differences, you best call Salk directly and have a talk.
Also, I'm not sure if they are available, but SS7F speakers are right in your budget
Swerd
Swerd
When I say 'speakers have similar voicing', I mean they sound similar across the mid-range – the most important part of music. In 2-way speakers, the crossover is right there, usually in the 2 to 3 kHz range. This audio range, in the middle of the speech-discrimination range, is where human hearing is most sensitive. In good 3-way speakers, the mid-range driver handles most of the speech discrimination range. It raises the mid-to-tweeter crossover to a much higher and less noticeable frequency, and allows selection of a bass driver that can go deeper without distortion or break-up noise.
All of Dennis's Philharmonic Audio and Salk speakers share well-designed crossovers, without audible dips or peaks across the crossover range. They perform well on-axis (directly in front of a speaker) as well as off-axis (off to the sides by at least ±30°). Good off-axis performance is critically important to a speaker's ability to create a wide and realistic sounding audio image, or in stereo a 'sound stage'. Speakers lacking good off-axis sound can make music sound like it's coming from tiny musicians inside the speaker cabinets. While speakers with good off-axis sound make those musicians seem to emerge from the cabinets and join you in your listening room. These features makes Dennis Murphy's designs stand above many other – but not all – commercially available speakers.
Edit: If it isn't obvious, I very much like speakers that are good at creating realistic images and sound stage. For what it's worth, the Philharmonic Audio BMR Monitor and BMR Tower speakers are the best at this among any of the speakers I've heard.
More money gets you better performance at the bass and treble extremes of audio. The drivers are more expensive, and deeper bass also adds to cost because it requires larger, heavier, and sturdier cabinets. Many floor-standing speakers can deliver bass down in the 40-50 Hz range (if the manufacturer is honest about performance). More money gets you down to the 30-35 Hz range. And much more money gets you down to about 25 Hz. Below 25 Hz requires crazy money. That's what subwoofers are for.
More money also gets you lower distortion and a more detailed sound, leading to a more transparent sound. For example, in the original SongTower, the very good quality Seas ER15RLY mid-woofers cost about $79 each (retail). The Veracity ST speaker uses the excellent quality Seas W16NX mid-woofers that cost $285 each. The ER15 driver has a smooth sounding paper cone with added reed fibers, and the W16 driver is made with a magnesium-aluminum alloy cone that goes deeper, has lower distortion, and has an overall more detailed sound.
Each speaker model has a custom designed crossover that blends the performance of the speaker's drivers. Different combinations of drivers require different crossovers. No standard off-the-self crossovers are used. That's an essential part of any good sounding speaker.
TheloniousEllington
That's an excellent and informative answer. Thank you for spending the time to discuss that with me. Everything makes sense in the way you described and is very interesting.
The bmr towers look really good as well as the veracity ST's. Thanks again!
