Isiberian, I read that story you linked to, and it seems they did not include a SET (nor would one have been a good match for the Maggies they used in the test; if they had, they would have been lucky to get more than 90db before the SET fizzled out). The tube amp they mention is a big, expensive ($6K/channel!!) push/pull type, which tend to sound more like SS amps, so it is not surprising to me that no discernable difference was identified in the ABX part of the study. Believe me, a single ended class A circuit is inherently more immediate than any push/pull, class AB amp out there, and they sound 'different' (I was going to put 'better', but that's too subjective...how about 'faster, cleaner, clearer, more spacious, more transparent, better dynamic contrasts, as though you're listenting to actual musicians instead of hifi gear playing a recording'...still subjective, but you get the idea).
Since the OP's budget would allow for such a system, and as some very good performing budget tube amps exist (Doc B, Decware, others), as well as any number of efficient speakers on the market, and since the OP is starting from scratch on a 2.0 or 2.1 setup, I felt it worthy of a mention. I know I could have saved some ducats if I had received the same advice.
Sorry for triggering a derailment of the thread!
