Well these are the two suggestions that have come through for the for commercial audio setup, this really is way over my head but I have been assured that these setups would work in a bigger space if eventually we moved elsewhere.
DTR-5.8
XM & SIRIUS Ready, 2-Zone 7.1 Channel
Surround Receiver- Rack Mountable Used for processing purposes only
Australian Monitor Commercial Stereo
Amp
The AMAV AV2.2P is a 1 RU stereo power amplifier. Designed for the demanding commercial audio-visual market, the AV2.2P delivers 100
watts per channel at 4 ohms from an elegant, slim line package. The
AV2.2P features front panel dual colour status LEDs, on board limiter,
ground lift switch and the option of bridged operation delivering
200 watts at 8 ohms.2 x 100 watts @ 4 ohm / 2 x 75 watts @ 8 ohm
1 RU chassis Convection cooled design for whisper
REQUIRE 3 x UNITS
OUTPUT
Turbosound Impact 55T x5
Compact passive 2-way speaker with a 5" LF driver and a 1" ferrofluid
tweeter plus integral multi-tapped line transformer. Compatible wit
brackets and OmniMount brackets, and includes 3/8" mic stand fitting. Weather resistant to IP54.
• 160Watt Output at 8ohms
Peavey PRSub
Rated at 400 watts program and 800 watts peak.It is simple to use, just connect your full-range signal and its internal crossover does the rest.
One 15" premium 2.5 inch voice coil woofer
and the second recommendation
Denon AVR2308
• Identical quality and power for all 7 channels,
100W x 7ch
• New 32 bit floating point DSP
• Compressed Audio Restorer
Denon's new audio technology forMP3/WMA/AAC compressed format to
reproduce higher frequency range and deeper bass sound.
•Latest version Mult EQ
-New tower type microphone for more accurate measuring
-Maximum six points measurement
-New filtering ALFC (Adaptive Low Frequency Correction) for higher resolution
processing in low frequency band.
• HD Video Circuit
-Discrete and latest devices for ultimate HD video performance in each block.
-Faroudja DCDi Processing up to 1080p
-Analog to HDMI up conversion
TOA Commercial HD Series (rear speakers)
• Variable impedance allows for
flexible installations
• 90 watts continuous
TOA Variable dispersion HX-5 (front and
centre)
The HX-5 is an innovative modular speaker design that incorporates the best characteristics of the traditional, cumbersome woofer enclosure combined with a CD horn-loaded high frequency driver and the fullrange
compact speaker enclosure without the drawbacks associated with each type.
• 600watt continuous power
The auditorium was used for film about 15 years ago on a short term basis and was stopped due to low patronage and poor sound quality. This is a massive space and the balcony alone seats 150 people, I can remember seeing films there as a child and it seemed big, cavernous & cold. It is a wonderful space for theatre but the ceilings are probably 30-40 ft and a crowd of 100 would rattle around in there.
Before they stopped showing movies they had moved the audience into the balcony which is carpeted and this worked well (except for the dodgy sound I believe)
