Topping VX1 Replacement Power Supply
Roboman1723
Amazon went full retard and sent me the wrong power supply with my Topping VX1 amp. I need a female 14V 4A AC/DC power supply but cannot find one anywhere, only males meant for laptops and monitors. I've looked at regulated power supplies but don't want to drop $40 on what should be a power brick. Can ANYONE help me! Please!
WaynePflughaupt
WaynePflughaupt
Any reason why you can’t just send it back?
Regards,
Wayne A. Pflughaupt
slipperybidness
slipperybidness
Send it back or call Amazon and make them send you the correct P/S. Amazon has great customer service, so this should be a non-issue! A hassle, but not a problem.
And, if you are going to replace a P/S, the P/S is the MOST IMPORTANT PART OF THE AMP!!!!! Don't cheap out on it, buy the $40 supply and be done with it.
I will also mention, a regulated power supply is a poor choice for an amplifier P/S, and SMPS is an even worse choice. Un-regulated linear P/S is the technically superior choice.
markw
Send it back to Amazon and tell them they shipped you the wrong item. That thought really didn't occur to you?
