Do you have room for a subwoofer? You won't be missing anything using bookshelf speakers if they are accompanied by a subwoofer. But it depends on the subwoofer, bookshelf speakers, and towers speakers being considered here.
Yes ShadyJ, I intendo to use subwoofers.
I already have 04 of them, Sony, with this spec:
Subwoofers (SA-WP16)
Speaker System: Active, Magnetically Shielded Subwoofer
Speaker unit: 250 mm cone type
Enclosure Type: Acoustic Volume-loaded Bass Reflex
RMS output: 165 W (6 ohms, 100 Hz, 10% THD)
Input: LINE IN (input jacks)
Power: 127 V / 220 V AC, 60 Hz
Consumption: 80 W
Dimensions (W x H x D) (approx.): 335 × 410 × 412 mm including front panel
Weight (approx.) 10.6 kg
Are they fitting?
