To Solder A Bannana Plug, or "Not" To Solder - That's the Question...?
slipperybidness
slipperybidness
There's zero benefit to soldering your connectors unless you are abusive to your cables. In which case, easy to remove and replace would still be better IMHO. Sound-wise, there's no difference soldered or not.
In audio, there is no true benefit.
Like I mentioned on post #14, in some of my other hobbies I need a more robust connection and those plugs travel with me sometimes so I like the heat shrink to keep out dirt and grime.
