Tips on how to mount LG GX77
  • Thread starter Thread starter fast fred
fast fred
fast fred
442
0
18
54
So I have the power outlet recessed and the HDMI cable pulling thru the same recessed area - see image attached for reference.
Any tips on how to do this the right way?? Do I mount the supplied bracket ABOVE the recessed outlet box?
If so am I able to tuck the cables behind the unit without adding bulk?
I think some of that depends on viewing height of TV. If that uses a low profile mount it will be tough to stuff all that wire behind it.
I would measure out a few spots where the braket will work and then determine where the top of the TV is located.
  • Like
Reactions: fast fred
I think your outlet is too high in relation to where you will want the bottom of the TV. Please view the LG video, which is (somewhat) helpful. It does a great job of showing how cables track within the display channels they've created and those channels is where your wall box MUST land. So, if the center of that channel is 12" below where the mount will be located, then you put your mount 12" above the wall box. Which, I think, leaves the bottom of the TV too high. But, that's just my opinion.
