This is driving me "crazy" - no mid bass
crazytiger
crazytiger
I am just going to run through this stuff, and y'all see what you think.....
Here is what I am working with:
PS3 for Bluray
Denon AVR-3805
Polk Monitor 50 fronts
PolK CS1 center
Bose surrounds (can't remember the model)
HSU STF-1 sub
Here are my current settings:
All speakers set to "small"
Subwoofer set to "yes"
Speaker distances measured and set correctly
Speaker levels measured with an SPL and are set correctly
Crossover set to 80Hz
Crossover on the sub is turned all the way up
Sub volume is set half way
Room issues:
My "theater" is also our living room and wife approval factor plays a huge role in speaker placement. The fronts sit in the built-in bookcase and are about 4' off the ground. I have moved the sub around the room trying to find the best location and ended up with it in the front left corner of the room. The room is rectangular, (approx 15' x 20') has a painted concrete floor, and vaulted ceiling. My guess is that those two things are hurting me the most. There is lots of furniture and a large area run in the room to "soften" it up some...
Here is the problem:
I've got great "highs" and great "lows", but relatively nothing in the middle. The Polks are very bright (which I like) and the HSU is excellent with the very low stuff. (hell, it shakes the chair I sit in from across the room!) Every thing else though is WEAK!!! There is a huge gap in sound that I can't seem to fill. I have "tinkered" with this stuff until I don't know which end is up any more. Is there a setting in the receiver I don't have set correctly? Are my fronts that crappy of a speaker?? Am I fighting a losing battle against inherently poor room acoustics? Is the HSU sub just really good at the really low stuff, but weak at the rest?
I have tinkered with speaker size settings, adding additional sub, changing crossover frequencies, etc... and I just can't seem to fill the hole!
Your thoughts?
TIA
PS3 for Bluray
Denon AVR-3805
PolK CS1 center
HSU STF-1 sub
Room issues:
Your thoughts?
TIA
Maybe the highs are not realistic and overpower the mids in perception?
A real time analyzer is needed perhaps
Lordoftherings
Lordoftherings
My thoughts.
Hi crazytiger,
Wow! You're not posting too often (only a handful or two of posts since Dec. 2006); perhaps I should follow your example (that would certainly keep me out of trouble). :)
I do have the same receiver than yours. :) I love my 3805; great mids by the way.
Now, the mid-bass covers the region from about 60 to 160 hz, where your crossover of 80hz from your 3805 happens to be. Also this area of the audio spectrum is one of the most difficult to get right.
I've beem through the exact same thing than you. Many things are at play.
Here's what I did myself trying to circumvent the problem.
1. Very important: You have to find out the setting from your sub where the "Phase" gives you the most output from your listening position. If your Phase adjustment is the switch type with the 0 & 180 degree positions, get the right position. If it's the type with a knob that adjust constantly, it takes a bit more time and experimentation.
* Now I don't know your level of knowledge on this, so I'll ask you simply; Do you know how to get the right position?
Also, check some good articles right here at Audioholics on this very same matter, from "Subwoofer adjustments".
2. I don't know exactly which inputs from your 3805 you are using, but here's one that has to be made in about 95% of all cases. On the "Input Setup" from your 3805 menu, there is the #2 point, which is "EXT. In Subwoofer level", from page 40 of your manual; set this feature at +10 db.
3. In my fairly mid-large room (actually, similar to yours in size), I also have my sub in the front left corner. BUT, I also have another same sub in the front right corner, which helps a lot, in the x-over region.
4. My two main front speakers are 5 feet (60") from the front wall; calculated from the front baffles of my loudspeakers. It's a position that was determined to provide the best balance for my particular room dimensions (by the way, mine is just over 23 feet long). And these two speakers are separated by exactly 8 feet and 2/3 (104"), again, calculated distance from the center of their tweeter drivers, and with great care as for best best balance in my particular room (mine is 13 feet and 1/2 wide).
* I use very precise measurements for all distances of all my loudspeakers in my room, using the right formulae. It's based on the nulls and peaks of our rooms' dimensions.
** For me: proper speaker positioning comes first, as my top priority. The rest; furniture and all that stuff, is secondary.
5. The subwoofer gain (volume level), on my subs are set at 1/4 position of it's rotary knob position, or perhaps a little tiny fraction more, but not by much (in my case, 1/3 position is wayyy tooo loouudd).
6. In my room, on my Denon 3805, the subwoofer channel level was set to minus 7.5db (-7.5). And this, by adding an extra 2db for compensation, from my own set of ears, and prime listening position. Also taking into account my Radio Shack SPL meter, innacurate results, using the appropriate compensation chart.
*** Now, I just give you the main points (there are others that affect the mid-bass region in our rooms), and some hints at trying to get the best compromise for that very difficult audio spectrum, which is very tough indeed to get right on correctly. BUT, because of your particular situation in your own room, your speaker's positioning (enclosed in built-in bookcases), the WAF, and all that derived from it; you are at the mercy of the biggest compromomises of all (women playing a very large role in your room). :)
~~~ These are my thoughts.
My advice to you: :) ............:).............. Take the 6 points that I just mentioned to you, and try to make the best of it. And of course, with the wife approval. So, that automatically means, trying to build a more solid foundation in your relationship with your wife, using sweet talking and gentle caress honestly feeled, tactics. If the heart is not there, forget it. :)
... You know what I mean...
I honestly don't know what else to add at this point, as I really feel that you did try your very best with all the several adjustments.
But one thing I want to say to you; Thanks a lot, for your best description of all your equipment, settings, speakers, positions, your room size...
Not many people gave us those important tools to work from. That helps a lot to understand precisely the situation, in this case, yours.
Hopefully, my post will bring some needed light in your mid-bass issue.
Don't give up, it's a constant battle.
And some people go to extreme length, to win it; using sophisticated digital Room EQs and those kind of tools that I'm sure you're aware of.
I'll spare you the enumeration, as there are several good ones; but your room has to be a considerable part of this equation.
===>>> But here's my best shot: Get a new A/V receiver, like a Denon AVR-4310ci, or an Onkyo TX-SR876; which both have Audyssey MultEQ XT automatic room correction & calibration, included in their DSPs horsepower crunching numbers.
Best regards,
Bob
Room issues:
Your thoughts?
TIA
Your room is very "live", acoustically and the highs/mids will reflect off of the hard surfaces, Since human hearing is more sensitive in the mid range, that can obscure the frequencies we aren't as sensitive to, especially when those frequencies are either being absorbed or weaker from the source. Yours may be weaker from the source since you have all of the speakers set to small. This puts the high pass crossover frequency above 120Hz in a lot of cases and this is right where you seem to lack sound. The concrete floor isn't helping but as long as the SPL isn't too high, it can be OK.
MatthewB.
Can you adjust crossover for each channel, if so set the mains to cross at 60Hz or even 40Hz if they can handle it.
crazytiger
crazytiger
Actually, I had considered that. Maybe the highs and lows are "too much" and the rest simply can't keep up - but to me, they sound correct. If I can just get a little more out of the middle, I will be quite happy with the system.
crazytiger
crazytiger
Hi crazytiger,
I have switched the phase on the sub, (0 to 180 and back - it's a toggle) but I can't tell any difference at all. I have tried it in real time during a movie, and also tried it with pink noise on my Sound and Vision calibration DVD. Maybe the switch is bad?
This one was out of adjustment. I checked it this morning, and it was set to "0". It will actually go all the way to +15. Should I stop at 10 or go all the way to 15? What exactly am adjusting here? Is this the same as adjusting the sub level in the speaker level set up? This is definitely one of the features that I don't understand. Also, I have not had a chance to see what a difference the adjustment made. I had to leave for work - will do some test-n-tune tonight.
Can't do another $$$sub$$$ right now, but maybe down the road.
Unfortunately, asthetics take priority over functionality in the room. Somehow, I am going to have to find a way to overcome this obstacle.
Mine is set to exactly to half way - anything more is too much
Yeah, I like the idea of the SPL, but I still make the final settings based on what my ear tells me.
Really, she will let me get away with just about whatever I want - as long as it is "camoflauge".
Best regards,
Bob
See above...
crazytiger
crazytiger
This sounds interesting. I don't know if the Denon will let me do that.
MatthewB.
My Denon 4802 and 3808 both allow this, so yu should be able to, this may solve your issue. Check speaker freq to gauge what to set the each crossover to.
Lordoftherings
Lordoftherings
Of course it will (page 36 of your Denon 3805 manual). And it is a good suggestion by Matthew. But your Polk Monitor 50s only have two small 5.25" drivers per speaker; so you cannot go at 40 Hz or even at 60 Hz; well, you can try 60Hz, but I really doubt that it will work.
By the way, your 3805 allow you to ony choose one crossover that is universal, for all your speakers, from 40 / 60 / 80 / 100 / 120 / 150 / 200 / 250 Hz.
In your situation, you have to leave the crossover at 80 Hz, not lower than that. But what you can try is 100 Hz, and see if you like it. That could be your ticket right here sir.
Now, follow these newer directives:
1. Phase toggle switch from your sub = 0 degree.
2. The EXT. In Subwoofer Level from your receiver = +10 db.
* This is for SACD and DVD Audio bass compensation. Don't worry about this, if you're not using the mutichannel analog input from your 3805. But you can still Select +10 db (it's the correct setting anyway).
3. Gain (Volume Level) from the rear of your sub = 1/3 position.
4. Redo the Auto setup/Room EQ (page 23 in your manual).
5. Make sure that your Room EQ is OFF (page 28 in your manual).
* Because if it's ON (Normal, Flat, Front, or Manual), it could very well be the reason that your mid-bass is all wrong. That too, could be your line saver.
6. Try that crossover at 100 Hz, as already suggested.
*** My "best guess". Your Polk Monitor 50, don't have what it takes.
By this I mean, that is exactly where the problem is. With two small 5.25" drivers in each speaker, there is something missing. And that something would be best created by some 6.5" drivers. That's my knowledge experience, it is not my opinion.
Recap: Try all these new 6 points, by following them to the letter, and by making sure that your Room EQ is "OFF". I cannot emphasize this last point more than this. And do the final tweaking by ears, just like you previously said. And by that, I mean the final level forv your subwoofer channel (page 34 and 35 in your manual).
* Come back right here, and let us know your new impressions. It should be quite interesting.
If, for any reason, you're still missing that something; then my "best guess", might prove to be the true antidote to your "something's missing" problem; which are, your speakers themselves, "crazy, no mid bass".
Cheers,
Bob
MatthewB.
Good advice Bob, but dual 5.25 should handle 60Hz, but since it is a universal crossover, I agree with setting it to 100hz, which will limit mid bass.
I think the problem is that your speakers have inadequate, or likely no diffraction compensation.
With narrow fronted cabinets like yours with drivers around 5", there is progressive loss of output starting around 600 Hz, and increasing at 6 db per octave as you go lower.
Now with your Monitor 50s, which are MTM, both drivers have to be fed the same signal. So to correct for diffraction loss the crossover would have to be complex, and sensitivity would have to be sacrificed.
Now those speakers are very inexpensive and of highish sensitivity. So my guess is that the speakers have no diffraction compensation. Speakers that have no diffraction compensation sound like you describe.
I have heard quite a few Polk speakers, not yours, but I never heard one I like.
The other issue is that for towers their F3 is a disappointing 57 Hz. There are many bookshelves that can manage better than this.
To ameliorate your problem as much as possible, I would place them right against a wall, and yes even in corners if possible.
I would set the speakers to full, and set your sub to twice the Fs frequency, which would be 120 Hz. Put the sub as close to one of the speakers as possible, as there will be sub localization issues.
If the mid bass tenor range is still weak in the wind after that, then it is time to go speaker shopping.
If you have to go speaker shopping, I would wait until you can up your speaker budget.
Lordoftherings
Lordoftherings
Hey Matthew, his Polk Monitor 50 are rated at 52 Hz to 24 Khz, without any given value (+/- db). Each speaker contains two 5.25" mid-woofs (I don't call a small 5.25" driver a woofer). Each speaker weights only 30 pounds. They are 35" high, by 7" wide, and 9.9" deep.
I gave you this specs, so you can undersyand better what we're dealing with here.
Yep, if he try a crossover at 60hz, he's in deep trouble with his surrounds. Can't do, it's just too much of a stretch. He has to compromise somewhere else.
And indeed, if he try the 100 Hz crossover, he just might find the missing piece of the puzzle. Nothing to loose for trying. :)
But, I'm waiting for his next results, because for one, I'm very familiar with his receiver (I own the exact same one), and also, I am counting on his HSU STF-1 subwoofer to do it's magic trick, if you can see my strategy here, which I think you do. Also, he has the Sony PS3, and the PS3 is a unique best to properly set up.
So, stay tuned, we are getting somewhere. :)
bandphan
bandphan
Like TLS said speaker shopping would be the ultimate solution. Even crossing the mains higher , without better crossover it will not matter much. The localized effect will be evedent.
Lordoftherings
Lordoftherings
I'm afraid that bandphan and TLS Guy are absolutely correct.
* That confirms what I said before about my "best guess".
Thank you both for this confirmation.
~~~ I am still curious at what he'll come to, with the new settings that I recommended, in particular the new crossover at 100 Hz (I think that 120 Hz would simply be too high, but you never know till you really try, right? :) ).
When you have this problem, it usually works out best to set the speakers to full,, so there is no crossover limiting whatever bass the speakers have. The best in room response then usually occurs with the sub brought in at F3 X 2.
However, I suspect these speakers have a dip starting at 600 Hz. The only thing that will help that is to use room boundaries to prevent the diffraction loss.
Lordoftherings
Lordoftherings
Tell me about it. But not with the Polk Monitor 50 (as full range).
And Bose for surrounds!
When I previously mentioned my "best guess", I knew it was it. But I'm just humble. :)
Actually, the best for him, is to get new speakers, a new receiver perhaps, but not necessary, there are ways around it, depending of your other components in your system. But with his PS3, YES, a new receiver is a better idea.
If he does not play it loud it should be fine.
This is a classic example of a good sub and poor speakers. When the OP goes and buys speakers next time, he should find speakers that sound great without a sub. All speakers should be very listenable without a sub. If a speaker screams connect a sub, pass it by. The sub should just guild the lily.
The sub should be the most expendable device in an audio system.
Lordoftherings
Lordoftherings
^ Totally agree with you.
But then, if you don't play it loud, you don't need such a nice receiver either.
And if you play it loud, you stil don't need such a nice receiver.
Last option left; buy new speakers.
crazytiger
crazytiger
I'm back......
After following Lordoftherings 6 step program, I did notice a difference, but the problem is still very much there. After reading through the other posts in this thread, it is apparent that I am battling a hardware issue more than anything - specifically front speakers.
Just so y'all know, I ended up with the Polk Monitor 50's when I found them on Slickdeals.net for $70 a piece - shipped!! hahaha Seriously, before the 50's I had the Monitor 10's and were satisfied with them. (of course I didn't have unrealistic expectations from a bookshelf speaker) I do like the Polks because they seem to offer more treble than other speakers in their price range. (cheap) When I saw the 50's for such a "good deal", I ordered a pair thinking that they would be as good as the 10's in the treble department, and would bring an appreciable amount of bass to the table. Boy, I was dead wrong. Oh well, chalk it up to experience I guess.
The Denon I ended up with when a customer of mine upgraded to one of the new "uber' Denons and sold me the old one for -- ya'll are going to hate me for this -- $100.
I bought the HSU sub after doing some research here at Audioholics. I love that thing - other than the fact that it leaves all my other crappy speakers in the dust! hahaha
I like what TLS Guy said about front speakers, "When the OP goes and buys speakers next time, he should find speakers that sound great without a sub. All speakers should be very listenable without a sub. If a speaker screams connect a sub, pass it by. The sub should just guild the lily." That makes perfect sense. What I need you guys to do is recommend me a set of "older" front speakers that will do the job for me. I am very much on a budget and cannot afford the latest 'n greatest. Surely there is something used in the $300 +/- range (pair) that will work. They don't necessarily have to be tower speakers either. If y'all know of a set of small speakers that will work well together (and with the Denon and the HSU) I'd be up for that too. I am open to all suggestions. Thanks again for everyone's help!
