KEW
KEW
It would be really cool if it looked like that to us in real life, but the 24FPS camera is what allows for the effects - frozen at 24Hz, slow forward at 25Hz, and slow reverse at 23Hz.
I think we process visual info at a "frame rate" of around 55-70 Hz.
3db
3db
This makes sense because the power frequency is set to 50Hz in Europe and 60 Hz in NA....we don't notice the flicker at those frequencies.
Have you ever used a timing light? That's very useful for checking the spray pattern in throttle body fuel injection when the injectors are exposed, like on a GM car or truck. If you used a DC power supply and an oscillator that's connected to the pickup, you could show this without a camera.
KEW
KEW
Yeah, that was my first thought when I saw the video was they were using a strobe light. But then I thought about what type of strobe light would be that effective outside in daylight and realized it was the camera frame rate producing the effect.
Probably, but a timing light is just as effective in sunlight because the Xenon bulb is extremely bright. The easy way to cause stop action is to record with lighting that uses AC- at 30 frames/sec and 60Hz AC, it's easy. At 24 fps/50Hz, it's close enough.
