If the couch is up against the wall, would in walls even work? Same setup as you...
edwelly Full Audioholic Dec 22, 2005 #21 If the couch is up against the wall, would in walls even work? Same setup as you...
CaliHwyPatrol Audioholic Chief Dec 23, 2005 #22 edwelly said: If the couch is up against the wall, would in walls even work? Same setup as you... Click to expand... I'm sure they would. If you put them about a foot above your couch and point the tweeters down, I suspect they would work out fine... But I don't know as I have never tried that! I'm probably going to just wait until I move to add the 6th speaker, although I would like to have it now I'm impatient....... ~Chuck
