mandyb
ok i am new here, hello all. i bought a tr-501 out of a van for $200 how bad did i mess up? can i make this thing work? it does not have a co-ax hookup. i can post a picture of the back of it if it will help. i can only get the wolfer and two sattlite speakers to work.
thank you
I
ifarrell
My guess is you get ripped off to the tune of $100-150. Here's a link for info about the "White Van Speaker Scam", and ways to prevent it happening to others http://www.scamshield.com/feature.asp?id=1 .
As for hooking the speakers up, what kind of system is this (4.1, 5.1?) and what are you attempting to connect it to (receiver or PC?)
Spiffyfast
Spiffyfast
i wish i could see these guys, never ran into one
mandyb
hey guys thank you for the reply. i am trying to hook this thing up to the dvd and tv. here is what the back looks like. thanks again for the help.
Spiffyfast
Spiffyfast
Ok, your only getting the L and R and the sub b/c thats all the signal you have running into it, the red and white cables you have plugged into the dvd input. To get all of them to work you need to run a 5.1 signal into the top 6 inputs. Does your dvd player have matching outputs like this, or do you have a receiver with pre-outs?
mandyb
no reciever, no plugs that match on dvd player. i have seen a cord out there that has, what looks a serial port and goes to a six prong rca. do i need this to make it work. thanks again for the help.
Spiffyfast
Spiffyfast
not sure what cord your talking about, so i can't comment on how it might work for you, without using those inputs at the top of that amplifier on the sub your out of luck with the surround sound and you'll only be left for the Front speakers and sub, sorry I can't help ya out anymore, maybe someone else on here might have an idea
Spiffyfast
Spiffyfast
I did see on their website that it has a coax input...can you take a more zoomed in picture of the inputs on the back of that, if it does have that we may still be able to hook up the dvd player for surround sound
mandyb
again thank you. it has no coax input anywhere on it. i guess that is the problem. i started with dual rca cords, then i went to the local video store and i was told how i should hook it up. that all made sense so i bought 40$ worth of cords,(all rca style) a single coax with rca plug. a cord with three plugs on each end red, blue and green. i ran the three way cord from tv to dvd and then wanted to run the single cord from the dvd to the TR-501 but the TR-501 does not have a single port for digital cable. here is a closer picture.
mandyb
sorry the pictures are not that great, not to easy with 100k limit. any way there really is not much to see red and white plugs and speaker jacks thats it basic labels such as aux, dvd, cd and such. the top red and white are labled surr, center, right and so on. thanks again for your effort
jaxvon
jaxvon
What kind of DVD player do you have? Most DVD players have 5.1 analog outputs that should correspond to the "Front, Back, Surround" etc.
Buckeyefan 1
Buckeyefan 1
Call them Monday and complain about advertising digital inputs. Make them buy the system back. Shipping should be about $25. ;)
http://www.trtheaterresearch.com/speakersystem/tr-501.htm
Copyright© 2002-2005 TR Theater Research.
sales@trtheaterresearch.com
Tel: ( 949)-355-6008 Fax: (714) 892-1802
Monday - Friday 8:00am - 4:30pm (PST)
If you want to see a scam, check this out.
http://cgi.ebay.com/Theater-Research-Audio-System-TR-501-Digital-Series_W0QQitemZ5792360581QQcategoryZ32861QQrdZ1QQcmdZViewItem
Here's another one about 5 entries down.
http://cgi.ebay.com/NIB-THEATER-RESEARCH-TR-501-5-1-CHANNEL-SURROUND_W0QQitemZ5793082981QQcategoryZ32861QQrdZ1QQcmdZViewItem
Here's the upgraded models.
http://cgi.ebay.com/Theater-Research-TR-503-850W-5-1CH-Receiver-w-Speakers_W0QQitemZ5791399728QQcategoryZ67918QQrdZ1QQcmdZViewItem
Check out the "buy it now" price on this one.
http://cgi.ebay.com/Home-Theater-Theater-Research-TR-503-Digital-Series_W0QQitemZ5794304950QQcategoryZ67918QQrdZ1QQcmdZViewItem
I've seen that set wholesale at www.made-in-china.com for around $40, but you have to buy in lots of 1000. It's probably a little better than your average PC surround system that you would buy at Staples, CompUSA, etc..., but you should know better than to buy from a bunch of knuckleheads in a truck. They are the Kirby Vacuum salesmen of the cheap speaker world.
mandyb
jaxvon, you are correct mine does not. i looked at them at the video store. what you are saying is that if i hook it up the analog i am analog.... i know this is my @#@$up, but the box says digital i see no way to make it digi. but i am very knew to this. thank you very much for the input it is greatly Appreciated.
Buckeyefan 1
Buckeyefan 1
What are the labels on the inputs in the white box at the top of the sub? there are six of them.
BTW, you don't need expensive cables. Digital coax and rca are the same thing-as long as they were made within the last few years.
mandyb
the ports in the white input box read: 5.1 input, top row of ports read: sub, cen middle row reads sr,sl bottom row reads r, l
i have e-mailed them and called them, but i think we all know who has the egg on there face. :eek:
i would just like to use everything i bought in some fashion. oh well
Buckeyefan 1
Buckeyefan 1
Mandy,
Don't sweat it. We've all made silly errors. This is a small one.
Aren't you glad you didn't pay retail?
Those are your digital dvd player inputs. Solution is simple. Just go to that local A/V store, return those useless rca's, and get your $40 back. Now go to Walmart and pick up a $49 dvd player with the 5.1 digital outputs on the back. Pick up the necessary rca plugs at Walmart for under $10. You're back in business, and have an extra dvd player to boot.
I have 4 dvd players, and only one of them has the 5.1 outputs.
jaxvon
jaxvon
Pardon me Buck, but I don't see any digital coax or TOSLink on there at all. Those sound like a bunch of analog inputs.
Buckeyefan 1
Buckeyefan 1
You are correct. They are analog. They will still reproduce the 5.1 surround sound Mandy is looking for from the dvd player. Mandy's speaker set is 5.1, so there's no option (or reason) to run in 6.1 or 7.1 at the moment. Sorry for the confusion. :confused: That makes the website guilty of misleading the consumer.
I still can't get over the MSRP's on their products. Jaxvon, did you see the speakers that look almost identicle to the Canyon Audio's reviewed here earlier this year? It's amazing what comes off the boat, and in the quantities - unreal.
jaxvon
jaxvon
Yeah, I've seen them. Whatever...
Anyway, thanks for letting me know you're still sane. It's just that you said:
I think you were referring to the player being digital, but as it reads, it sounds like those are digital inputs.
