Peter Nielsen said:
What caused the tweeter to blow? The automatic calibration? (Fortunately the tweeter and midrange on my Maggies are protected with fuses).
BTW, did you hear about the TCS Mk III that is suppsed to be released later this fall? It will supposedly have HDMI v1.2 and allow us to run SACD and DVD-A in digital all the way. I'm going to upgrade as soon as it's available...
Peter
I eagerly await all new TACT products... but yes, I did know about the TCS MKIII. Im not sure how SACD and DVD-A is going to be run digital all the way unless Denon iLink is also incorporated. Nevertheless, make use of your ADC6 for now, b/c listening to 5.1 audio through that setup is already amazing.
When I first got my TACT gear, I did not know what I was doing and made extreme corrections that added significant gain. I also had my tweeters separately amped. I also made the mistake of picking "yes" for digital amps when I was using solid state amps... this sends a max signal to the amps. The result was a few blown tweeters. That's what happens when you think you can figure things out without reading the manuals.
Just make sure you use a reasonable level for your impulse response during testing and that your corrections don't add significant gain. I tend to have my corrections attenuate the signals by 1 or 2 dB compared to bypass mode. If you setup properly, this won't be an issue.
Do pm me with any questions you may have during setup. I know the end results will give you the best listening experience you have had with your speakers, but I don't want you to get frustrated with the learning curve, which is steeper than what you experience with most gear.
