The Large Budget System!!!
Hanse18
Hanse18
I find towers completely unnecessary for surrounds. My setup will be used for less than 10% music, so I'm more concerned about HT performance, and towers would actually be detrimental in that aspect. You shouldn't be able to locate surrounds, hypothetically speaking, and if I had towers back there I would definitely know where the one closer to me was. Maybe if I was the only person living in my house, and I only had to worry about my sweet spot seating, towers would work, but I need seats from wall to wall.
Yeah, XLR cables... I am going to look around because outlaw's seem overpriced. I am so terrified of the horrible, horrible ground loop that I may cause (3 or 4 power outlets, 2 cable feeds, 1 antenna feed, sounds like a ground loop waiting to happen to me), the last thing I need is a 60hz hum just because I didn't use balanced cables.
Buying the proper cables sucks.
I must have been really tired or something, but last night I was actually thinking about making it a 7.1 system, and hanging a couple of speakers from my ceiling behind me. I must be crazy, but I'm still considering it. That would be about 1000 extra bucks though, I don't think it's gonna happen with the original purchase, but I'm definitely gonna do the wiring so it will be an optional upgrade in a year.
Are you planning on using the included mic to calibrate your system, or are you getting an spl meter? I'm probably just gonna try both, because I have never manually calibrated speakers before, so I'm unsure of my capabilities, but it looks pretty simple.
jaxvon
jaxvon
dannv said:
lol ya hidden costs : ( the biggest shock for me was the 125$ balanced cables i need to conect the pre to the amps. well i will be buying my setup in july, so you will have yours before me and can tell me anything you learned.
I definantly feal that you get alot more speaker for your buck when you go towers for surrounds.
Why are you spending that much on balanced cabling? Guitar Center/Musician's Friend sells the same thing for way less money. Heck, even Impact Acoustics has a great deal. I think Blue Jeans is great quality, but I think that's a bit steep for a short interconnect.
http://www.impactacoustics.com/product.asp?cat_id=808&sku=40059
Just search around on the internet some more. Remember, the balanced cables you want are identical to the common XLR-terminated microphone cable. Before you buy, verify that you're getting a good shield, that is, NOT a spiral shield, and at least one braid shield with 90% coverage.
Why you don't want a spiral shield:
http://www.audioholics.com/techtips/audioprinciples/interconnects/spiralshieldvideocables.php
jcPanny
jcPanny
dannv said:
What makes the emotive amps better?? i looked at them and decided to go with the outlaw setup, which is also cheaper and comes with free shipping. The outlaw setup has a seperate 200 watt AMP FOR EACH CHANNEL. I wont even have to worry about the all channels driven thing, i will just have to worry about enjoying the very impressive 200 watt rms amps.
dannv,
The emotiva amp is a monoblock design with a seperate torridial transformer for each of the amp channels. This is why you can add and remove mono or stereo amps in any of the 7 slots. It is comparable to the outlaw solution and would require less cables and power cords and be easier and cheeper to add extra channels.
Sounds like you will have a great system.
jaxvon
jaxvon
The issue with the Emotiva is that it didn't quite hit its power spec, so the Outlaws are still offering more juice.
dannv
after all the savings on the outlaw setup the emotive ends up being much more expensive, but i definantly considered it and it would be my second choice. anyways thank you for the advice and plz inform me if anyone finds any deals of comparative items, i am looking to save some cash, ive got kids to feed.... well i have myself to feed.
