The Dts Advantage ?
dobyblue
dobyblue
The studios will keep releasing in whatever format they want to release in. Fox is exlcusively supporting DTS-MA on Blu-ray and has many discs with DTS tracks on them.
There are more discs currently available with completely lossless DTS on them than there are with lossless Dolby, although lossless PCM outnumbers them both.
mtrycrafts said:
Yes, you will as you are not comparing apples to apples. You have no idea how the differences were derived, inherent to the algorithms or mastering and eq-ing. Many years ago, the two formats were compared as best it could be at the time, it was all over the place that the algorithm would not cause, hence, external manipulation in the processing.
After all, DTS had to have a gimmick to sell it.
The biggest selling feature of DTS when it first came out was far from a gimmick. DTS gave studios the ability to create one version of the film without caring what soundtrack was on it. Because Dolby and SDDS are encoded onto the film strip you had to have a different stip run off for each country's language. With DTS you were able to run off one strip and just create the discs for the language.
