The Denon of all Denons
It would be except that it lacks a few current things that likely even much lower models have today (3D, hdmi pass through, etc...). If you don't need the features, then that thing's a beast.
shadyJ
Speaker of the House
Staff member
While I would love to have it, at 100 lbs that thing would be a major PIA. I have a Pioneer that weighs 70 lbs, and moving that thing around is a massive hassle. I had it on a solid shelf, but the wood still bowed when I set it down there, so I had to brace the shelf and double the thickness. That Denon would need at least two guys to move around if you aren't a body-builder. It is well past the point where it's more sensible to just get a preprocessor and separate amps. It's a dumb unit targeted at the kind of guys who also go for Humvees.
surveyor
surveyor
What Pioneer Model do you have at 70 lbs it must be awesome?
surveyor
surveyor
I'd bet that beast could be used as just a very fine 10 channel amp, if one wished to use a newer model AVR with pre-amp outputs. What do you think?
If you needed 10 channels of power for a partially distributed system or a 9.2 setup or something, I don't see why not.
M Code
M Code
Was a great AVR in its day...:)
However times have changed and there are multiple new audio, video and connectivity technologies available the 5805 lacks...
Just my $0.02... ;)
Yeah, I don't like HEAVY either.
I would prefer my AT3005 weigh 25 lbs, instead of 100 lbs. :D
How much do they weigh on your planet (Krypton) :p
- Rich
They have the same mass. :D
But I don't know the weight since I can't remember what the gravity was on my planet Krypton. :D
surveyor
surveyor
ATI amps are sweet- especially 300W x 5! I really like my Outlaw 200W x 7. The ATI and Outlaw both have a weight problem. But skinny amps are'nt for everybody!
Agree, that's why I am thinking of adding cast iron balls around the heat sinks of my lightest one in order to improve the dynamics and add authority to the bass.
surveyor
surveyor
Why didn't I think of that?:D
M Code
M Code
Hmmm..
You guys must be smoking some funny weed...:eek:
Best3175
Best3175
Funny thread. I have a 5805 and am looking to upgrade to a 7200WA. I have given pause and thought about making the jump to a pre/pro and using the 5805 as my amp. How is cross-channel noise? Is this a viable options?
At a 100 awkward pounds, it would be nice to utilize it as a amp just so I don't have to move it our of my basement.
Seth=L
Seth=L
If the 5805 had a bypass mode for all processing and preamplifier sections and allowed you to use it as a straight amplifier I would say yes, but I doubt it does. You'd get a perceptible amount of excess noise from two preamplifier stages and a whole lot of unnecessary clutter. If you want to go separates, go separates. If you want all in one, get the 7200wa.
It helps if you start a new thread for this kind of question. I almost didn't go to the bottom to read your post when I saw this thread was from 2013.
Best3175
Best3175
That's what I thought.
I'll make sure to start new threads. Thanks
