Dan Banquer said:
From what I understand there has been much contoversy on how to measure headphone distortion. Some have claimed to you must model the inner ear and others claim you don't. Some headphone "experts" have stated that if the headphone is not placed perfectly over the ear then none of the distortion as frequency response numbers they give will be meaningful.
Looking at the issue as logically as I can, it is not disputable that frequency response varies considerably with a headpnone mesured in open space vs. a headphone coupled to an ear/canal structure. The various cavity structurs cause peaks/nulls in the uppermidrange and treble bands that cause signficant frequency response deviation(s). Logically, when the amplitude efficiency of a specific frequency is raised and coincides with the harmonic of a lowr fundamental(e.g.; 5khz peak and it's relation to 2.5khz fundamental), the amplitude of the measured harmonic product will be higher resulting in a different THD value upon analysis. So in this respect a THD measurement, if to be accurate represenation of what the ear detects, must weight the frequency response effects of these cavities*. But then one can debate this -- as is the point to measure the characterisic of the headphone or of the cavity effects upon the headphone? But this effect is not the same in low midrange and bass frequencies. At lower frequencies, the response is different for an open air vs. coupled headphone onto a stucture as well, but this is due to the proximity, air cavity and it's relative air volume compliance effect not the specific cancellations/peaks in respnose due to the specific dimensions of the canal, pinnae and contained space(s). Obviously, once the wavelenghts reach a certain length in air, the cavities can not cause cancellation/nulling and peaks due to the small dimensions. A simulation device with approx. correct proximity mic placement and volume of space should not require a precisely simulated ear/canal structure.
(Ref. from above) Ironically, considering the effect of path lengths and effect on FR/resonance(s), one must also think about the accuracy of referring to low frequency distortion in speakers, if one does not account for the room effects that must differ from the open-space characteristics considerably.
As far as frequency response is concerned most of the recording engineers who use headphones on a daily basis that I have talked to and my own experience with a few different brands of headphones leads me to conclude at the moment that both frequency response and distortion specs appear to be dubious.
INdeed, I believe them to be correct, if by this you mean correlation of FR vs. the same data from a speaker measurement. With the headphone being coupled directly to the ear and with no HRTF(head related transfer function) or crossfeed effect as naturally occurs with speakers, the FR measurements of both can not be weighted identically, at least not into the midrange and treble bands. However, I suspect if one was to measure speakers using a binarual head and then match this response with headphone on the head, that the resulting sound would be comparable. I'll get around to trying this one day...
If the headphone needs to be placed perfectly over the ear for the their specs to be real then realistically how often does that happen?
Good question. The ear structures of differing people, while averagable, are unique between individuals. This does prevent an absolute accurate method of measurement. However, I believe that average useful measurements that are 'mostly' accurate and useful are entirely feasible.
BTW: If you have any papers or articles on this subject of headphones please e mail me or send me the links. I have the distorion paper by Jamie Moir. I have read it at least ten times
Unforunately, I am not aware of any specific articles on THD and relation to headphones specifically.
P.S. Thanks for the articles you sent me earlier, if I didn't thank you already.
My memory is not so good about this, I'm afraid. I can not remember sending you any articles. LOL.
EDIT-I now remember the papers I sent. Your welcome.
-Chris
