hamitup
if amps,receivers have similar ratings: thd and power whats the big dif
Doug917
Doug917
Many receiver ratings will be inflated when you consider a channels driven at the same time, while amps will be able to hit their printed specs much more often.
REceivers sound different due to other decoding chips, DACs, and other factors. You should really listen to several recievers before you buy to hear the one that sounds best to you.
hamitup
thanks, didnt think i would get a response this early
jcPanny
jcPanny
Amp vs. receiver
Almost all amps are stable into 4 ohms, while most receivers are designed for a 6-8 ohm impedance.
When properly compared, there is no difference between them:D
Of course, if not, then stand by:D
