Hi all,
I'm looking for a speaker with following characteristics:
- Amp integrated + Full range sound (no external subwoofer)
- Inputs: Wifi + Bluetooth + Analog line input (RCA, mini jack,..)
- High quality sound and volume
- Ideally be able to be built out to multi room / surround system at a later time when my budget allows for it
- +- max 500€
After some research on internet I came to a short list of products which match (most of) these criteria:
- Teufel one M ~ 480€ (I even found a new one for 400€)
- Denon Home 350 ~ 569€
- Sonos Play five ~ 557€ (Would require external bluetooth receiver)
- Bluesound pulse mini 2i
Since they all check off my requirements, my first reaction would be to go be to go with the Teufel one M as it is significantly cheaper. (I'm not very experienced rating sound quality of speakers based on technical specs..)
Which of these speakers would you recommend and why? Also, don't hesitate if you think above list misses a product that I should look into.
All suggestions are welcome!
Thanks in advance for your feedback,
Bart
