Testing Subwoofer imput signal & or subwoofer speaker
MisterrG
Yamaha Natural Sound AV Receiver Model # HTR-5450
Monoprice Powered 8" Subwoofer Model # MSUD-A082
Is there away to check the subwoofer output signal , to confirm if the signal is
working correctly.
My powered subwoofer wasn't working correctly( Alot of background static) ,
Replaced builtin amp with a brand new one but still just alot of background static &
nothing else.
PLEASE HELP ???
Mister-G.
G
Grandzoltar
A multimeter. I might be wrong but it should read 2.83 volts. If your getting 0 then you that’s your indicator
L
Leemix
If you have left and right or zone 2 pre outs you can connect to one of them just to check if clear or same.
No, you can't test it with a multi meter. You need an O-Scope. Best to connect it to a known good preamp like the preouts zone 2 or other channel preout if you have them and see what it sounds like.
This would be an unusual fault for a receiver, but possible. More likely than not you have a driver with either a damaged voice coil, or cone voice coil separation.
So connect the drive directly to a speaker output and see what you get.
Replaced builtin amp with a brand new one but still just alot of background static & nothing else.
How old is this 8” subwoofer?
Have you played some really loud low frequency bass? :D
