Terminated Bi-Wire?
N
Neijii
Is there a place that sells good terminated bi wire speaker cable? Just looking to see if I can buy it with the banana plugs already hooked up.
ratso
ratso
although i've never specifically asked about bi-wire, the first place to start IMO with any cable needs is blue jeans cables.
Adam
Adam
Here is a link to what Greg got.
EDIT: Here is a thread that discusses those cables, and below is the picture that Greg put up for them.
Alex2507
Alex2507
Quick Note: The take away message is that bi-wire is a waste of time for sound quality. ;)
Tri-wire on the other hand ... just foolin'. :p
If you absolutely HAVE to bi-wire, save yourself a bunch of money and get some decent looking 4 conductor speaker cable. Or, two runs of decent two conductor and get some nylon mesh to cover them with.
N
Neijii
I don't HAVE to bi wire..I have the Totem Mites and my father just got the Ascend CMD 340. Figured Bi Wiring might be a better option since it gives the choice..
