(very loud) at one point the speakers sounded fine but i tripped a breaker. Is there anything available to get constant power to the amp? I have noticed that the display with flicker at times as well.
Hi Justin,
If you tripped a breaker, there's not much you can do aside from moving your high-power devices to separate circuits. I would probably start with separating amplifiers, as they are definitely going to consume the most power when used at high volume; preamps, processors, DVD players, etc. will consume negligible power when compared to amps.
If, like me, most of your stuff is in one room, you might have trouble actually accomplishing this. My whole living room is on a single circuit. If you are going to be playing at those levels on a regular basis, I would consider dropping in at least one, new, 20 A circuit for your system. Indeed, I am considering it for my own room. It may or may not be an easy job, depending on a number of factors, but it's really the best and most appropriate way to fix that problem.
Good luck!
