Sickening, maybe:
IMG_5565.mp4 video by airsoftsniperm4 - Photobucket
As far as the issues with tapped horns, aside from size, the main one is bandwidth. For reference though, I believe a tapped horn will actually be likely smaller than an equivalent front loaded horn (although the FLH would on paper have better performance.. not sure about audibility).
A tapped horn will only give you around 2-3 octaves of usable performance, the rest will be resonant. That tapped horn operates from around 15hz to 60hz and does need EQ to get flat. Probably better suited to a setup with some pro audio bass drivers handling from 60hz to 120hz... it's a bit convoluted IMO and the box size requirements don't help.
A vent will give bandwidth up to about 1/2 an octave below the vent resonance, which is usually around 150hz or higher.
Compared to that, a well-stuffed TL or a decently low Q sealed box will give you bandwidth as high as the driver can go. The sealed box will lack bandwidth down low without EQ and thus likelyhood of thermal compression though. THe lower the Q, the easier the driver will move so less thermal compression and easier extension, but also more driver motion so power handling gets risky.
My Mal-X is sealed with a Q of .55 or so. While I've never put it through a window flexing test, I think it's all the low distortion output i'd need for my tastes. The problem is that i don't have an easy room (it's almost all concrete except one wall and the open floorplan behind it), and so i get a few response dips. I really want to add two more subs to smooth things out.
Out of all of the above, sealed is still the best way to get infrasonics below 10hz, because it won't sacrifice bandwidth or become dipole below tuning.
That's my suggestion to OP... get what you wanna get, but get a few drivers within your budget rather than just one killer sub. it'll make things easier IMO. Four Mach V Pi-18s, for example, or maybe Four CSS SDX15 Mk IIs if four LMS-5400s is too pricy. Then seal them up, as that will keep box size small, and then equalize.
