Swerd, thank you for your warm welcome, and thank you very much indeed for your notes and advice. You have clearly gone out of your way to research on my behalf and I much appreciate it.
Yes, the speaker model I posted was a typo and it is indeed the Tang Band W4-1337SDF that I’m focused on. The first post on a new forum should be accurate, right? My bad.
Funnily enough, at the moment, the drivers I have are in the model shown in the YouTube video you found. I was looking for a TL build and I came across it by chance, liked the idea and paid the designer for the plans. As a build, it was very easy but I’m not totally happy with the sound. The speakers are in a large living room and look attractive, which keeps the wife happy, but low frequencies are poor and according to a sound engineer friend of mine, who has younger and much better ears than mine, the highs are missing too.
So, I’ve decided to put some larger speakers in the living room (when my wife is out…) and try the TBs in another, smaller enclosure and use them as bookshelf speakers. The Bandit looks good and I might well consider that. I wrote to Tang Band directly as they have enclosure suggestions on their site, and they replied very promptly with a design recommendation, though it seems to be a bit generic for their 4” full-range drivers. I’ll spend some time at the weekend looking at the various options, including the Parts Express one. As I’m living in Greece, it will be a bit difficult to actually call them, but we’ll see,
BTW, if you are interested in seeing the TL and/or TB build specs. I will gladly share them with you (or anyone else who might be interested).
Many thanks again.
