speakerman39
speakerman39
Would someone here explain a few of the T/S Parameters to me? I am familiar with Fs, Xmax, Qts., Qms., Qes., and etc. but what about Pe and Bl??? Is Pe the power rating in RMS OR Peak??? How can I calculate Bl? Anyways, I would apptreciate someone taking a few minutes and explaining this to me. Thanks for your time. Have a great day. :):)
annunaki
annunaki
Moderator
I did not like some of the descriptions on the link you provided (nothing against you Warp :) ). They can be somewhat misleading depending upon how it is understood. The explanation of BL for instance makes it seem that you want to purchase a sub with the highest BL factor as it will have the strongest motor. All T/S parameters are interrelated. They are measurements of the sum of the parts working together as a system. For instance you would not choose driver A over Driver B simply because it has a stronger motor expressed in BL. It may have a stronger motor because it has substantially more mass, xmax, or it is simply not a real efficient design and requires a lot of motor force.
I guess what I am saying is don't fget too concerned with any one parameter. They can begin to give an idea of how a woofer will perform but only with much experience. Even then you can be thrown for a loop now and then. :)
speakerman39
speakerman39
I really appreciate the links guys. I somewhat now have a better understanding of the T/S Parameters.
Warpdrv
Warpdrv
No offence taken whatsoever annunaki
Hey thanks for adding a more clarifying link, as I really have no technical basis to give info, just posting what I am finding here...
The more info for me the better....
speakerman39
speakerman39
Hey Warp more info for me too............LOL!!!!!! :p:p
speakerman39
speakerman39
Still not clear about the Pe in that is it Peak power OR RMS??? I would think RMS but admit I could be wrong. What do any of you think?
annunaki
annunaki
Moderator
Pe is the thermal power handling of the driver. So yes, it should be RMS power of the driver.
