Yup you guys are totally right. I did lots of equipment rearranging and tests (not for this issue, but I am getting lots of new stuffs lately) and I am 100% sure that it is the base noise of the receiver. If it were the speaker wires, then if I turn my other equipments off (TV, computer, DVD player) the noise should go away but it does not. So I know for sure my speaker cables are well-shielded and the receiver puts out the base floor noise.
I know ambient equipment does generate hiss as well though. It probably does add to the noise floor through the speaker wire but not in a significant way (it's probably -200 db or something). My ambient equipment does generate noise into my line-level cables...which I can hear if I turn the volume knob to maximum (and of course, play no sound, otherwise I am in for trouble). It is funny, I can even identify which piece of equipment is generating which noise into the line-level cables because the funny noise sounds the same as the hum my various devices put out.
For example my TV which emits a 15600 Hz high-pitched whine at all times due to it's scanning rate, also sends that same whine into my line-level cables. If I turn the volume to max with no sound playing, I hear that whine out of my speaker tweeters. My computer, which emits a fuzzy fan-like sound, sends that same sound into my line-level cables as well.
I also figured out why I never noticed the receiver base floor noise before. It was because before I had it hooked to my computer....and my computer emits FAR louder noise out of itself (fan, hum, hiss, etc) than the base floor noise of my amp. So that noise was totally drowned out even at nightime.
