I have an old Mirage Nanosat 5.1 system that I am looking to enhance. Upgraded my receiver to an Onkyo NR-595 last year and looking to connect the Atmos capability. I am planning to take the front left and right nanosats and use those for atmos and as such, will need to replace those two speakers. That is where I am soliciting advice and recommendations with Mirage no longer being in existence.
These replacements need to be “wife” friendly and as such cannot grow to much in size. Looking for something in the size range of the Martin Logan 2i/4i or Definitive ProMonitor 800/1000. Looking to spend now more than $500 for the pair. Thoughts???
Thanks
Hmm your only upgrading front speakers? I don’t understand micro speakers, infinity has towers on sale right now that would destroy any small speakers. Sorry you gotta go small , I’d consider arx bookshelves or the .
I’d say this is right under minimum size for a center it may work , emotiva c1 is better tho .
I’d go for 5” + drivers on all
Speakers. Def technology feels like an sideways upgrade but get larger model .
Center channel speaker
www.crutchfield.com
I’d convince your wife or just get infinity 263 and explain towers are superior. Get whatever the largest center you can afford it’s most important or upgrade it after fronts if your budget is too low .
good luck, I wish Ihad gotten larger Klipch icon towers but 6.5” woofer seems fine.
go big or go home, anything beats satellites.
