Switches fo my setup
Dickie B
I need help to make my setup easier. I have a turntable, a tape deck, a preamp and I computer. I also have four sets of speakers but I've got that figured out and working.
Sometimes I want to run the turntable output direct to my receiver, other times (when I'm recording an album) I want to run it to the preamp and then to the computer. Now I climb around the cabinets moving cables around. Then I have the same issue with the tape deck.
Is there a reasonably priced switch I can get to eliminate constantly moving my cables around.
Thank you.
Generally they're called "receivers". You might want to post up all the specific makes/models of your gear and connections....
Thank you.
Look in eBay for an old Radio Shack Tape control center. There is no current equivalent. You can not switch the turntable unless you add a phono preamp between the turntable and the switch. The you would not use the RIAA input.
3db
3db
Thank you.
What model receiver do you have?
