Not necessary. Again, omnidirectional soundwaves.
More than anything, I would try to get at least 2-3 feet say from your speaker and a corner/wall, like you have it in the photo. No closer to that closet.
That is something you can experiment with... toed in at your ears/ toed in crossing in front (weird, yes, but I've seen it) / toed in slightly so that you can still see the inner-sides of the speakers (aimed past you and crossing behind you) / or perpendicular to the front and back walls. Every speaker and room is a little different.
This can be complicated. Because the Low Frequency Soundwave are so big, it is easy to find yourself in nulls. (This is why multiple subs come into play.) There are places in a room where a person could somewhat accurately predict problems. Say if your room was 20' x 20' x 10', and your sub was in the front wall, and you were on the back wall, you would be in a null most likely. Your room isn't like that!
As I said before, I would crawl out the best 2-3 spots for your sub based on your main LP. You can guess placement, and you may guess wrong. My example is valid: corner placement isn't always the best. Every room and scenario are different. With your ceiling, especially so: it may help or hurt your cause. My instinct is that you should shoot for 7-11' away from LP, and the distance from sub to each speaker should be different and irregular. Also, since you have some low frequency source on that front wall with your speakers, I would personally look to put the sub elsewhere and potentially benefit from exciting a different room mode than what your speakers might. My instincts say right wall where your file cabinet is, or left wall just to the near side of the window, further from your speaker. My next spots would be to look near the corners of your back wall, but not necessarily in the corners. Still try them out in the corners, but be willing to experiment!
