SVS PB12-plus setup
djreef
djreef
I would say that depends upon what your REW shows. Both your sub and your prepro have correction limitations. My room has such terrible nodes that I PEQ'ed both of my Plusses, then ran YPAO (Yamaha's PEQ), and then polished them off with a DSPeaker Anti-Mode 8033 subwoofer PEQ. There are a lot of filters in the loop, but it's the best I could do. (Remember, when trying for a flatter frequency response, it's much better to cut peaks than to boost dips.)
Not to worry, it might be a little work, but you will end up loving your new SVS. :)
Ya, it's frustrating trying to fill a real good suckout.
DJ
N
Nuance AH
The REW measurements will tell you (and us) everything. Get to it! :D Also, give us a shout if REW is giving you problems.
timoteo
timoteo
Quote: "fill a suckout!" haha thats what she said!
Wow im so immature! :)
mdanderson
mdanderson
Thanks Tomorrow for the additional info. I just need a little patience in trying to get everything sounding right.
E
Ed Mullen
Manufacturer
In order to maximize the performance/output of the PB12-Plus, set the gain as high as possible and the AVR sub channel level as low as possible, while still maintaining the same overall calibration level.
Example - if you are at -15 on the subwoofer and 0 on the AVR sub channel level, set the subwoofer to -3 and the sub channel level to -12. The calibration level won't change, but the sub amp will make more power.
GlocksRock
GlocksRock
Does this hold true for the older bash amps as well?
mdanderson
mdanderson
Thanks Mr. Mullen for the input. I have talked to you a few times on the phone and you have been very helpful. My PB12-plus is really sounding great now for movies and music.
E
Ed Mullen
Manufacturer
No - the BASH analog gain stage behaves very differently than the Sledge digital gain stage. Typically a BASH amp can be driven to full output by a typical AVR with the gain set to around 10 o'clock to 12 o'clock.
E
Ed Mullen
Manufacturer
Excellent news. If you need anything else, give us a shout. :)
