Here are some THD sweeps for the f113:
and here is some for the 18.0:
Keep in mind the maximum output sweep run on the f113 is at 115 dB, but for the Funk sub, that is the
minimum sweep for that chart. The Funk never crosses over 10% THD at a 115 dB sweep, but for the same sweep level the F113 pretty much stays above 20% THD at 40 Hz and below. The JL Audio subs gets outperformed by a wide margin. Don't get me wrong, I am not trying to trash JL Audio. It is, after all, it is a much smaller sub and has a bunch of extra features like room correction. I would love to play around with some W7 drivers which look amazing, but for performance for the dollar, it doesn't compare too well with Funk, as well it shouldn't with so much less woofer surface area.
As for the amplifier and power line questions you have, I take your point, but I don't know the details about that stuff. I believe that Funk uses the
Speaker Power amps that JTR and Seaton uses. As for CSA or UL certification, you will have to ask Funk or Speaker Power about that.
