I have the following speakers in my home 6heater
Receiver: Yamaha RXV-667
Center: Paradigm CC-370 V2
L/R : Paradigm Monitor 7 V3
Subwoofer: Paradigm PS-1000
My subwoofer does not work properly and I will buy an SVS PB-2000
The HT is in the following room:
Width: 12'
Length: 20'
Height: 7'
Seating distance: 8'
I have the following questions for adding surrounds (5.1 or 7.1 configuration) - I did research in the forum and web site but I want further advices:
- Are in-ceiling speakers for side and back surrounds a good alternative for on-wall speakers? Reason: 3 children that will play in the basement
- Looked at the following In-ceiling speakers: Paradigm CI Home H65-R, Paradigm CI Home H55-R or Paradigm CI Pro 65-R. Any other possible options?
- The ceiling will be a suspended ceiling (vinyl tiles made by Ceilume), Roxul Safe and Sound will also be used.
- If I use on wall speakers, monopole or bipole speakers will be better? I have a feeling that using monople speakers will be OK since I only have 1 row will 3 seats.
- For the surround speakers can I use other company speakers like the SVS Prime satellites? Otherwise, I think I will use Paradigm Atom Monitors;
- If I use bipole speakers, what is the opinion on the Paradigm Monitor Surround 1 or Monitor Surround monitor 3
I included a plan of the home theater room.
Thank you for your help.
Frederic
