surround speaker question
selkec
selkec
Does it really matter if the surround speakers are matching in brand. I know it does with the front 3 speakers with timbre matching but how important is it for surround speakers. I will addd that I do not listen to multi channel music. Only used for HT use.
XEagleDriver
XEagleDriver
Not really
Selkec,
For your application (HT and not MC music) it does not really matter.
If your AVR or pre-amp allows you to set different crossover frequencies for different speaker sets (front, surrounds, rears) you have even more flexability to mix and match speaker types/sizes.
My touch of OCD, plus an afinity for MC music, causes me to use same brand, model series, and woofer size in all my speakers--but that is not your situation.
Cheers,
XEagleDriver
son-yah-tive
son-yah-tive
I did, just to be safe. And also in 5Ch mode they all sound great together.
Halon451
Halon451
Currently I use a different brand as my surrounds, but that's soon to change. Have really had zero complaints with this arrangement for HT use, although on a more subtle level I just crave the consistency of a well rounded system with matching speakers all around. I rarely listen to any multi-channel music, as such any music listening I do is usually in 2-ch stereo mode anyway.
The general consensus is to ensure your front three are matched at least, since this is where most of the sound in a standard 5.1 track comes from. This gives you a more consistent SQ as the audio pans across the front back and forth, while the surrounds are mainly for effects sounds and such.
selkec
selkec
Thanks everyone. I ask because Im living in an apartment and I think having 4 of Polks biggest towers is too much. I ended up with this setup because my want to have wood grain speakers and not black and Frys had an awesome deal on Polk rtia9's in cherry at Christmas. I had to get them and that freed up my original polk towers. Now Im thinking of selling my rts150's to a friend and looking at different surrounds. Im also loking at dipole/bipole surrounds. Polk makes some but only in black or white. I want cherry. So that brought me to the axiom site looking t the Qs8's. Which would fit my situation perfectly plus I like their design of quad directional sound.
So does anyone know how axiom compare to polk in sound. I think I have heard they are bright which most also say about Polk.
jostenmeat
That is a lot of money to spend for mismatching surrounds, no? I've done mismatched surrounds, and it works perfectly well for HT, but then I ended up matching them in the end. After that experience, I will always try to match if at all possible. And while I've probably now seen hundreds of movies on my PJ setup, my new must-see bluray for new guests is now actually a classical music concert bluray, where before that might have been Rataouille, or The Dark Knight, or Kill Bill, etc.
IMHO, it's not necessarily worth spending so much for bipoles/dipoles, of course, only in relation to one's total budget for the entire HT. Monopoles work great too for much less cost, particularly if it's a small viewing area and/or the room setup doesn't allow for such designs. Dipoles need to be placed so that you sit in the null, and bipoles depend more on boundary interaction than monopoles. BTW, I currently have bipole side surrounds.
selkec
selkec
I think for now ill stick with my rti150's as rears since they are tll enough towers that the tweets and mids can reach over the top of my couch. Plus I guess this way I can get an amp for my rears and have really kick ars multi channel music if I ever try it. It just seems like alot of speakers in one room in an apartment. Its 5 of polks biggest rti line speakers in one apartment living room. It rattles everything. Good thing my neighbors are young. No complaints yet.
