Surround Speaker Height?
DDigitalguy06
Hello to everyone.
I just order some yamaha speaker's for surround sound use.
The problem is that i wan't to mount them on the side wall, because my room doesn't allow for back rear mount. But the problem is that the height that the surround speakers are, there gonna be about 7 ft above ear level. is that good or bad? or should i point them down a little bit.? when i have a chance i'll post a pic of were i'm putting the speakers at.
BBrunner
DDigitalguy06 said:
Hello to everyone.
Although Dolby has their own specs, do whatever sounds better to you. This is the only thing that matters. But, yes, I do suggest tilting them down a little. Good luck!
DDigitalguy06
Thank u for the quick response.
I just don't wanna have to use speaker stand's. plus it will make my room ugly. that's why i'm mounting them on the wall. but thanks for the reply's.:)
