Surround Sound + Xbox 360 Help
House
Toslink is the optical cable.
You said in one of the earlier posts that your getting audio out of your tv. Did you plug the white/red of the composite cables into your tv? there is a white/red bundled together, and a red/blue/green bundled together. The r/b/g ones are video, the r/w are audio make sure those are unplugged.
Does your dvdcombo reciever have a setup menu? Does it support DD inputs?
what model is it?
I tried with the red/white unplugged from the TV. Nothing.
I think it has a set up menu, I've messed with how far away the speakers are from me in it...stuff like that.
I'm not sure what DD inputs are..
I don't have access to the model #, I'm at work right now. It's from 2002 if that helps.
House
I finally got it to work! Ater like 2 years! :D I looked at my optical slot more closely and it's actually says output not input. So I think this is why it's not working. So I tried hooking up the red and white sound cords into my receiver's AV slot and it works now.
