I chose the Debut Carbon EVO as best bang for the buck in 2021. It came with the Ortofon Red so they must be trying to increase margins by switching to the Sumiko Rainier (Sumiko does make some good cartridges). I have not changed the stylus to the blue yet but may some day. The speed switch is underneath with no markings so you have to remember which direction is for 45 or 33.
I later switched to the acrylic platter. The steel platter on the EVO has a damping ring which does reduce resonance, but it still rings. The platter change was more for aesthetics though as I doubt the steel platter produces any audible noise. Here's the TT with the acrylic platter:
The other items I would add are a dust bug (if the doc ever finds another) and a tone arm lift. I worry about falling asleep with the needle in the out-groove and would just like the convenience of an auto-lift. There are plastic ones that work ok but I question their reliability as the damping fluid can leak or dry out. I am saving for a Tru-Lift which is made in Canada. They are expensive but fortunately the Carbon EVO takes the smallest one which is cheapest. They just use blue tack to stick it down so it does not mar the plinth.
Enjoy the new table when it arrives!
