Yes, I did get a good deal on this subwoofer - however the guy who sold it to me is a friend of mine and wouldn't try to pawn it off on me if it were broken. He had a two week return policy but I took too long getting it setup to figure this out (shame that). It worked fine when we tested it and I don't recall any hum then. The sub is from 1993 as I said, which begins to make me question that thumping as being an inherent flaw from the age of it.
TLS, everything in my system is two prong. The Preamp, amp, CD player, tape deck, turntable, TV, all of it except the 360 which is hooked up to the TV. I thought the 360's three prong plug might have been messing with it but it was humming before I even plugged the 360 in to the outlet. Yes, what you said is correct about the hum when nothing is plugged in. And by "set to Large" I take it you think I'm using a receiver or preamp with such a setting - I am not. There's nothing in there for me to tell it the size of my speakers. I can hardly see no sub being a good alternative to a pair of bookshelves which lack low end without one. I play games and movies on this - point being I need bass for those things.
Just-some-guy, I haven't tried that but I'll give that a go as well. It won't matter if I can eliminate this hum if the sub still thumps when I turn it off - I'd just assume never turn it on in the first place if it's going to do that so for all intents and purposes I'd rather not even use it. It was playing at his house fine with no hum, it just seems to do it in my room.
