Subwoofer with Surrounds?
Pensacola Hi-Fi
I have an extra sub laying around - what a great problem I am thinking on using it with the surrounds. It is a 5.1 system and am wondering if anyone has done that, if it is worth it? and any general thoughts.
Here is the rest of the system.
Def Tech 7001
Def Tech 3000
SVS 16-46
BPX Surrounds
I have an old M&K 8 inch sub or a HSU VTF2 MK@ that i could use in the back. The wires are run in the walls/attic and think that I could easily splice them and send them to a wall plate in the middle of the back wall, then back up and to the BPX.
Thank for the help.
bpape
I don't think it will buy you much since the surrounds should be cut off at 80Hz according to the spec.
You might be better using it as a 2nd sub in the room to help smooth response from the LFE channel.
Bryan
