Yes HDMI will carry the signal, but you have to make sure 1) the player is setup correctly to send the signal via digital (HDMI) The player should not be set to "downmix" or "PCM", 2) the subwoofer is turned on in the receiver's setup menu - sub "yes" and at least some of the speakers set to "small", and 3) the disc you've selected has a DD/DTS track and you have selected that track (receiver should display DD, DTS, etc...)
