If you get gasket tape at the hardware store, make sure it is the high density closed cell type, not the open cell foam.
I just built a similar subwoofer, using the shiva plans, an Assasin 12" and the remote controlled 250 watt plate amp from parts express. I cut 1" from the full length port, and used gasket tape under the port and speaker.
That thing shakes the room watching movies. It feels like the wind is blowing my hair on the pod races.
It is a little 'loose' on the music for my taste, but some of that is undoubtedly the room and the positioning of the sub.
Now I need to make a couple of those Eros MkII speakers, and get rid of the crappy pioneers I have for my front speakers.
