Subwoofer for SR506 (low-estimate)
SirLouen
SirLouen
Like 1 month ago, following some advice from this forum I bought a Onkyo SR506, and some Behringer B2030P for my 5.1. Now I'm using an old Subwoofer I had from before and I'm planning on upgrading it.
My room is about 25 m2 and I'm looking for a low estimate subwoofer (~$150) that may fit greatly the whole system I'm bulding.
Any ideas regarding this?
Regards,
SL
SirLouen
SirLouen
Yes I was thinking exactly on that subwoofer... problem is I'm from Spain and I cannot find Dayton brand here unfortunately, so I was looking for something a little bit more "commercial" if possible :(
Thanks for all :)
mazersteven
mazersteven
I don't know if they do, but you might want to look and see if Amazon.com ships to Spain.
SirLouen
SirLouen
Unfortunately not... anyway parts express does, so I might be buying them (problem is the customs and the taxes)
By the way, what difference I may encounter between Dayton 10'' and 12'' (except $20 difference), do you recommend me definetly the 12'' model for that diff? (and considering the characteristics of the Onkyo 506 specially)
Thanks
SirLouen
SirLouen
Finally I was deciding to shipping the Dayton to Spain but I have find that while sub cost $150, shipping cost $250!!! Not a good idea...
So now I'm up to find new ideas of low estimate subs but a little bit more commercial so I can find something in Spain :)
Anyone can tell me something?
What do you think on Behringer S1800S?
Regards
V
voltainthesky
What about an Energy ESW-10? MSRP is $370 but they are going for about $150 online right now. Don't you guys think that would be a better sub than the Daytons?
http://www.energy-speakers.com/na-en/products/esw-10-specifications/
edit: I also bought a refurb Onkyo 506 about a month ago from shoponkyo, and those Behringers are on my list of possible speakers for a 2.1 setup. What do you think about them, and what kind of music do you listen to the most? This is going to be for in my bedroom, and I am probably going to get an Energy ESW-8 for my sub.
SirLouen
SirLouen
Keep saving. You need a budget to work with.
Don't you think the Behringer S1800S is a good idea?
I have this other possibilities:
Peavey Messenger Pro Sub passive
Tapco SW10 Subwoofer
Any good for a HT that can be compared with the Dayton SUB120?
Davemcc
Davemcc
Right off the bat, the Behringer and Peavey subs are passive, which means they do not have a built in amplifier to drive the speaker. Unless you can budget for the cost of a separate amp, these will do you no good. Also, these are professional sound reinforcement speakers that will likely underperform in a home theater environment. Neither of them will play below 45Hz (which doesn't bode well for the Behringer with an 18" driver).
Tapco I've never heard of. I see they invoke Mackie as the designers of the sub in question but I have no basis to say that the results will be good or bad.
In this price range, I guess I could belatedly suggest you look at Sony subs. I had a little Sony that I paid $100 for many years ago. Within it's design limitations, it performed yeoman's duty without a single hiccup or failure. In this ultra low budget category, I guess I could say Sony=safe, you will get what you pay for. My little Sony is still in service today at one of my friend's homes.
V
voltainthesky
....or you could go with the Energy ESW-8 that I mentioned on page 1 that no one is commenting about.
SirLouen
SirLouen
I have the Onkyo 506 Amp... then Peavey passive sub won't work with this?
About the Energy, I cannot find it neither :( I feel we are really under stock here... I've seen a lot of subs here in the forums but none of them can be find in spanish shops (nor european e-traders).
BTW, The Tapco looks a good idea, but I don't have a good reference about, only have heard so I don't know if its worth
SirLouen
SirLouen
No, but Peavey also makes a powered version of this sub although it is much more expensive.
I've seen the Peavey Messenger Pro Sub P active for about the double cost.
Between the Peavey Messenger Pro Sub P active ($360) and the Tapco SW10 Subwoofer($230), what would you recommend me comparing quality/prize?
Would both perform good on a HT?
When I was planning to buy the Dayton($150) I had the idea on buying a pair, but now as this cost much more, I'm just planning on buying 1... would you still recommending me the pair?
SirLouen
SirLouen
What about the JAMO SUB200? Any ideas about this sw? it costs around the Dayton SUB120, but don't know if its can be compared in quality :(
