I suggest getting a test disc such as Stereophile's disc, which has samples of lots of different frenquencies. Use the setting that gives you the most even response over the bass frequencies. If you want to get real scientific, you can get a sound pressure meter that measures frequency bands and measure to see if there are peaks or valleys. For either means, use the setting that works best and don't worry about theory.
